dc/dc ssr problem
Discussion in 'General Electronics Chat' started by kwhkwh, Aug 9, 2016.
  1. kwhkwh
    Jul 19, 2016
    33
    should there be output voltage on a dc/dc ssr without input voltage thanks,,,kev
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    Show circuit!
    Max.
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
    See off state leakage in the datasheet..
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    What is the partnumber of the DC/DC SSR that you are using?
    In the attached datasheet there is the "off state leakage current" given of max 1μA.
    Bertus
  5. kwhkwh
    Jul 19, 2016
    33
    hi al,l I have used a fotek dc/dc 100 amp output from ebay, with a max 40 amp output pwm, I supplied 9v to the pwm and connected output to ssr input ,I then connected a small dc motor to output of ssr using 9v supply and a blocking diode without turning on pwm, the motor ran, I disconnected pwm and still the motor ran. I then connected my mutimeter to out of ssr and it showed zero. could the ssr be faulty. I tested the pwm with the 9v motor on its own and it works great, but I wanted the ssr to control a high current heater thanks for any help... great site...kev
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    I don't see any DC-DC Fotek SSR's on ebay, do you have a link, are you PM'ing the input??
    Max.
  8. kwhkwh
    Jul 19, 2016
    33
    hi I bought a 40a max pwm works fine I then bought a fotek 100a dc/dc ssr off ebay I connected 9v to input of pwm and output to input of ssr ,output of ssr to small dc motor with 9v supply including diode. without imput from pwm motor ran when 9v applied disconnected pwm completely motor still ran could it be a faulty ssr...thanks kev
  9. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The SSR is likely a DC/AC relays.
    It will not turn off with DC.
    As said before, Give us a link to the used SSR.
    Bertus
  10. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    I don't get how you are configuring PWM to a SSR??
    What are the details of the PWM.
    Why introduce a SSR?
    Is this one of the Ebay $5.00 specials?
    Max.
  11. kwhkwh
    Jul 19, 2016
    33
    hi thanks I cant find a link but it is advertised on ebay uk as bgbulkdl7 and yes I am using pwm on input of ssr thanks again
  12. kwhkwh
    Jul 19, 2016
    33
    hi cant find a link but is selling as dc/dc ssr on ebay uk
  13. kwhkwh
    Jul 19, 2016
    33
    hi I wanted to use the ssr as a high current pwm controlled supply to a dc heater and yes it is a £7 unit
  14. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    Show how you have it hooked up, the motor should not run without any input on the SSR.
    What voltage is the heater?
    Max.
  15. kwhkwh
    Jul 19, 2016
    33
  16. kwhkwh
    Jul 19, 2016
    33
    I connected a 9v + supply to the ssr output I then connected the - supply to the motor and then from the othe motor connection to the negative out put of the ssr including a back emf diode across the motor . without input from the pwm the motor ran at full revs? thanks
  17. kwhkwh
    Jul 19, 2016
    33
    the heater is approx. 13v I used a small dc motor to test the ssr before running a high current through the ssr
  18. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    A SSR with no input the output should normally be OFF, .
    Max.
  19. kwhkwh
    Jul 19, 2016
    33
    thank you this why I think the unit is faulty do you agree thanks for your time
  20. kwhkwh
    Jul 19, 2016
    33
