dc dc multiplier
Discussion in 'General Electronics Chat' started by dkthechamp, May 14, 2010.
  1. dkthechamp
    Mar 3, 2010
    10
    I want to converter a DC signal between 20mV - 90 mV into higher range of DC 200mV to 900mV. Both active and passive solutions can be considered.
    Any suggestions/reference would be greatly appreciated.
    Thanks,
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Would something like an op amp with a gain of 10 do?
  3. retched
    Dec 5, 2009
    5,201
    313
    NO. Wait. Yes. yes it would. ;)
    OP, what are you trying to do with the signal?
  4. dkthechamp
    Mar 3, 2010
    10
    Since i'm working in CMOS based technology, an opamp can't work as the input signal is too low to generate enough Vgs for any MOS based transistor !
    The basic idea is to convert this DC voltage signal of range between 20 mV to 90 mV into current form (A V/I converter). But due to very low amplitude i classic solutions are not adaptive here.
  5. retched
    Dec 5, 2009
    5,201
    313
    If you are using an active solution, I dont see why it would be a problem.
    These are done regularly in micropower harvesting. And even digital scales.
    Are you restricted to a particular design technique or is this a challenge or assignment where you must adhere to specific standards?
    Basically what Im asking, Is: Does anything go?
    Im going to go ahead and give you a link I believe is doing what you want.
    It can and has boosted 34mV to 1v. It is used to generate power from body heat for use in pacemakers and other equipment where battery access is difficult.
    Operates from 20mV to 250mV input, and outputs 1v
    http://wireless.ee.washington.edu/papers/CarlsonOtis_VLSI2009.pdf
  6. retched
    Dec 5, 2009
    5,201
    313
    And here is an IC to do what you want:
    http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1799,P90287
  7. dkthechamp
    Mar 3, 2010
    10
    Thanks for your response and the link. But the said paper is about getting a regulated supply of 1 V and i'm interested in converting the voltage between 20mV-90mV to a range, let's say between 200mV-900mV.
    The multiplication factor should remain constant for this particular range. Certainly i don't loose the amplitude during conversion, as it would a loss of precision for the targeted application.
    **I'm aware of this IC but i'm working on an integrated SoC, hence no other chip but open to few external passive component if at all necessary.
  8. AlexR
    Jan 16, 2008
    735
    54
    An opamp would work and Vgs has nothing to do with it. Think bias!
    However as it is a fairly low level signal and you seem to need a high impedance input you might be better off looking at an instrumentation amp.
  9. retched
    Dec 5, 2009
    5,201
    313
    I see. negative biasing, or using a -v on on the instrumentation amp, will handle it. Vgs shouldn't be a no concern.
    [ed]
    Ive gotta refresh sooner. Quick Alex. ;)
    [/ed]
  10. dkthechamp
    Mar 3, 2010
    10
    Could you please provide any circuit/reference on this, which consumes ultra low power (of the oder of few nWs) and can work with a Voltage supply Vdd of 1.2V.
    Thanks to all :)
  11. retched
    Dec 5, 2009
    5,201
    313
    I do not have any hands on experience with any of the nanoWatt ICs you are interested in, but I can offer some direction.
    Start searching for micro-power harvesting technologies, schematics, and components.
    This should give you a good start on your journey.
    dkthechamp likes this.
