DC DC Converters
Discussion in 'General Electronics Chat' started by Sidra Khan, Nov 25, 2015.
  1. Sidra Khan
    Sep 16, 2015
    6
    i a using an isolated DC DC converter..i wanna know if i don't short the -ve output and input ground annd want to use the -ve output as gnd for the rest of circuitry, how would i do it actually?
  2. crutschow
    Mar 14, 2008
    13,477
    3,362
    If the converter is truly isolated then you can connect the input ground and output ground wherever you want.
    The only restriction would be the isolation voltage limit between the input and output (which is usually stated in the spec sheet).
  3. Dodgydave
    Jun 22, 2012
    5,143
    768
    What is the model number of the converter, or circuit diagram?
  4. Sidra Khan
    Sep 16, 2015
    6
    you mean that if i am using 24 to 12v converter i will connect 24V and GND to input + & - pins and can get 12V and gnd at out + & - pins. And i can connect the rest circuitry to these output pins! it will work correctly?
  5. Sidra Khan
    Sep 16, 2015
    6
    i am using vicor VI-j00
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    24Vin between 1 and 4; 12Vout between 5 and 9. You can tie 4 to 5 or 4 to 9, or not tie input to anything on the output.
  7. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    That is a cranky old part. Any reason you are not using their 2nd gen (Maxi, Midi, Mini) bricks? I've found them to be still a bit Vicor-weird, but not as weird as the VI-J.
    ak
  8. Sidra Khan
    Sep 16, 2015
    6
    if i don't tie any input to -output, can i still use -output as gnd to drive the rest circuitry?
  9. Dodgydave
    Jun 22, 2012
    5,143
    768
    Yes, you can do what you like.
  10. MikeML
    Oct 2, 2009
    5,451
    1,066
    Yes. But dont call that electrical node "Gnd" unless is connected to a metallic rod driven into the earth. A better name is oV or Com.
  11. Iqra Mehmood
    Jan 3, 2016
    for emi reduction, how will i connect emi filter before dc dc converter and what about grounding?
