DC-DC converter
Discussion in 'The Projects Forum' started by pratapkollu, Jan 13, 2011.
  1. pratapkollu
    Thread Starter Active Member
    Dec 13, 2006
    42
    Hai
    I need a DC -DC converter
    input is from USB , 5V
    Output required , +12 V , GND, -12 V
    Does such DC-DC converter exist?
    What is isolated dc-dc converter?
    Thank you
    Pratap
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What is your output current requirement?
    You might get up to 500mA output @ 5v from a desktop computers' USB port; a laptop will have considerably less available (~250mA-300mA).
    Converters might be around 85% efficient, so you might get up to ~88.5mA current from the +12v/-12v outputs.
    You can purchase small pre-made DC-DC converter units at reasonable prices in the States; anywhere from ~$6 to $15 USD.
    For example, here's a 2W unit for $6.24: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=102-2093-ND
    Datasheet: http://products.cui.com/getpdf.aspx?fileID=5072
  3. masa6614
    Nov 9, 2008
    49
    A isolated DC/DC means the input and output of the converter are isolated from each other. There's no direct wired connection between them. The 5V and it's GND are isolated from the +/-12V and its GND by use of a transformer.
  4. marshallf3
    Jul 26, 2010
    2,358
    201
  5. pratapkollu
    Dec 13, 2006
    42
    Thank you all for the replies and help
