DC DC converter, on off pin question?
Discussion in 'General Electronics Chat' started by eddie500, Apr 28, 2016.
  1. eddie500
    Nov 5, 2011
    21
    I have this DC DC converter and want to understand how it turns on and off.
    It says this in the manual how to enable it (ON / OFF ) in the picture below.
    My question is, can I put a regular push button (on/off) switch between the enable and Vin- for it to turn on and off?
    Thank you
  2. Veracohr
    Jan 3, 2011
    560
    77
    I believe so, it says low logic turns the module on.
  3. shortbus
    Sep 30, 2009
    4,098
    1,697
    Your push button would need to be the type that stays on when pushed and needs a second push to release.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
  5. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,710
    1,302
    In bench qualifying lotsa converters over the years, I've never seen switch bounce cause a problem - and I've tried. I drive an enable transistor with a function generator, starting at 1 kHz and slowing down until the output wakes up. Usually it takes 50 ms before anything happens. Vicor's bricks are spec'd at something like 100-150 ms.
    ak
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I didn't say the TS had to do anything about it, just that he should be aware. It is pretty simple to eliminate.
