Hey guys,
I'm using the DC/DC-Converter TMR1-2422 from Traco Power (Dataseheet: http://www.tracopower.com/products/tmr1.pdf )
to generate the supply voltage for the following OP-AMP:
http://cds.linear.com/docs/en/datasheet/1028fb.pdf (The LT1028 CN8)
My question:
1. I m connecting the common pin to the "OP Amp - ground" and NOT to the ground of the +24V external supply. I think this should be correct right?
2. Would it be better to put a ressistance between COMMON and the OP Amp ground? If yes how would you chose it? I got 0 idea.
Hope you ll be able to help me.
Cheers and BR
Alex
My question:
Cheers and BR
Alex
