DC-DC buck converter
Discussion in 'Homework Help' started by Nkutau, Oct 14, 2011.
  1. Nkutau
    Oct 10, 2011
    A dc-dc buck converter has the following parameters: f= 20kHz, ton= 20μs, L=400μH, Vs=20V and R= 20Ω
    1. Calculate the average value of the output voltage and current
    2. Calculate the minimum value of the inductor necessary for the buck converter to operate properly
    3. For given value of L, calculate the value of the capacitance for ΔV of 37.5mV
    4. Calculate the the max and min values of the inductor current
    Can you please help me with the above
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    The Homework Help section asks that you post up the work you have done so far, so we can see it and find where you went wrong, or suggest better approaches. We will not do all your work for you.
    If you are in doubt about how to structure your post and what to include please read this thread: http://forum.allaboutcircuits.com/showthread.php?t=3002
    Thank you.
  3. tgotwalt1158
    Member
    Feb 28, 2011
    111
    18
