dc-dc boost converter
Discussion in 'General Electronics Chat' started by shuaib khan, Jul 16, 2012.
  1. shuaib khan
    Jul 16, 2012
    hi, i want to design boost converter .i dont know how to implement it on pcb.can you help me.
  2. Sensacell
    Jun 19, 2012
    1,184
    277
    ... And I want to design a bridge!
    You gotta include a some parameters if you would like to obtain our free, kind and courteous services.
  3. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    hi. for instance, you could just place the electronic components on the PCB. I mean, why not?
  4. absf
    Dec 29, 2010
    1,493
    374
    You can start by reading the attached PDF.:D
    Or give details on what are the specs on the boost converter you wanted.
    Allen
  5. takao21203
    Apr 28, 2012
    3,578
    463
    OP isn't giving any information for instance frequency.
    Keeping PCB tracks short is a good idea but some cm are OK.
    Issues are too specific to each circuit to give good generic advice. For instance cooling grid will emit EMI to a degree that a temp. sensor (NTC) connected to small LCD thermometer will actually shut down the same!
    Solution: inline 1x 330 uH- issue solved.
    You should have an ability to think into the circuit, and should build a prototype, before you layout a PCB.
    Cracking point #1 is the storage coil (or the flyback transformer).
    If it is not the right one, efficiency won't be good.
    The OP should give information if a schematic to use already exist (or not).
    Or all advice is only guesswork.
