DC-DC boost converter
Discussion in 'General Electronics Chat' started by robert.guttormson, May 18, 2011.
  1. robert.guttormson
    Oct 3, 2009
    26
    I am designing a boost converter for a motor drive that accepts DC voltage and transforms it to AC. The motor drive accepts 320V DC input. I tried following the principles of a simple boost converter but the output never converges after following all the equations. I added a more than necessary cap to smooth out any ripple. I have simulated a pulse for a particular duty cycle. As usual, I dont know why it doesnt work, read through the other threads on the forum but couldnt figure out. Any or all help is appreciated. TIA
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Well if you will work in CCM then
    D = (1 - 140V/320V) = 0.56
    So for F = 40KHz
    Ton = 14us
    L_min = (14us * 140V)/ ( 2 * IL) = 3mH
    So if you want to use coil 55uH you need Ton = ( L * 2*IL) /Vin_min = (55uH *0.6A)/140V = 235ns ----> F = 0.56/235ns = 2.3MHz.
    So if you change L1 =3.3mH and Ton=14.1us then you will get 320V in LTspice after 250ms
    And for DCM change L1= 680uH and Ton = 10.5us
