dc damping
Discussion in 'General Electronics Chat' started by vks_foe, Jan 21, 2013.
  1. vks_foe
    Thread Starter Active Member
    Jan 11, 2009
    55
    5
    Can somebody please explain how we design the damping RC network for DC circuits with inductive load as shown in this page[​IMG]
  2. crutschow
    Mar 14, 2008
    13,488
    3,372
    Your figure does not show.
  3. BillB3857
    Feb 28, 2009
    2,402
    348
    thatoneguy likes this.
  4. gootee
    Apr 24, 2007
    447
    50
    I have read most of the snubber-design papers that are on the web. At least two of them gave a practical procedure to use for an existing circuit, which I have paraphrased elsewhere and will paste below:
    PRACTICAL SNUBBER AND TERMINATION DESIGN
    Below is a pretty slick and practical way to determine parasitic capacitance and/or inductance, and the characteristic impedance and optimal damping or termination resistance (and optional series capacitance) needed when ringing or reflections (as the case may be) are present.This is a very simple method for determining the capacitance and the inductance that are causing an LC resonance in a circuit or a transmission line or PCB trace, which also gives the characteristic impedance for the resonant circuit, which is often everything needed in order to know how to damp it, optimally. (I refer to the C and L as parasitic. But this method and the math may be used when either one, or both, or neither is parasitic, in case an installed inductor and/or capacitor are involved.)
    This assumes that there is a ringing condition, already, such as might occur on a digital buss or a transmission line or PCB trace, or in a switch-mode power supply or an AC-to-DC transformer/rectifier circuit, and in many other types of circuits. (If you don't have ringing and just want to determine some of these parameters, I guess maybe you could try hitting your circuit with a pulse train and decrease the rise and fall times until it rings.)
    1. Measure the frequency of the resonance or ringing, using an
    oscilloscope (or a circuit simulator, if you've modeled the parasitics well).
    2. Add a shunt capacitor and adjust the value of this capacitor until the frequency of the ringing is reduced by a factor of two. I've left out the math but the value of this resulting capacitor will be three times (3X) the value of the parasitic capacitance that is creating the resonance.
    3. Because the parasitic capacitance is now known, the parasitic inductance can be determined using the formula:
    L = 1 / [(2 · π · f)² · C]
    where f = (original) resonant frequency and C = parasitic capacitance.
    4. Now that both the parasitic capacitance and inductance are known, the
    characteristic impedance of the resonant circuit can be determined using the following formula:
    Z = √(L/C)
    where L = parasitic inductance and C = parasitic capacitance.
    5. The resistor value used for the terminator or for the RC snubber circuit should be equal to Z, the value of the characteristic impedance, and the capacitor, if used, should be sized between four and ten times the parasitic capacitance. The use of larger (than 4X) capacitors slightly reduces the voltage overshoot at the expense of greater power dissipation in the resistor.
    NOTE: The resistor, alone, is all that is needed to prevent or damp-out the ringing (or reflections, as the case may be). But if power dissipation in the R would then be too high, a C is added in series with the R, so that only the unwanted frequencies cause currents in the resistor. (And that, boys and girls, is the only reason there's a capacitor in a snubber.)
    Cheers,
    Tom
  5. tinamishra
    Dec 1, 2012
    39
    Power semiconductors area unit the center of power physics instrumentality. Snubbers area unit circuits that are placed across semiconductor devices for defense and to boost performance. Snubbers will do many things:
    Reduce or eliminate voltage or current spikes
    Limit dI/dt or dV/dt
    Shape the load line to keep it within the safe operating area (SOA)
    Transfer power dissipation from the switch to a resistor or a useful load
    Reduce total losses due to switching
    Reduce EMI by damping voltage and current ringing
