Is it possible for high pitched sound to be emitted when a DC current is discharged at a high rate for example during direct short to ground from a battery source?
It is often the exclamation that comes from the one who shorted the battery to ground!Is it possible for high pitched sound to be emitted when a DC current is discharged at a high rate for example during direct short to ground from a battery source?
Unfortunately, I don't know the mechanism. I do know that I heard a mystery whining sound, and when I disconnected one of my lead-acid batteries, it stopped. That battery would normally be maybe 13 volts, but it was down to 10, and I was unable to charge it.how might this happen? Are u referring to the gasses escaping the battery or some other cause?
Inasmuch as a direct current metal-arc is, necessarily, 'disruptive' (and, hence, 'oscillatory') in nature, it would seem possible from a theoretic standpoint --- Although I cannot claim personal experience of the phenomenon...Is it possible for high pitched sound to be emitted when a DC current is discharged at a high rate for example during direct short to ground from a battery source?
by Aaron Carman
by Duane Benson
by Jeff Child
