DC curent on a 6 phase system
Discussion in 'Automotive Electronics' started by Petros.Alexakis, Jun 8, 2016.
  1. Petros.Alexakis
    Mar 10, 2016
    8
    Hi all
    A quick question. If the phase current on a 6 phase system is 380A rms what is the the DC current?
  2. Kermit2
    Feb 5, 2010
    3,852
    968
    RMS is a way of stating AC currents in equivalence with a DC current
    An AC RMS current of any amperage has the same POWER as the same DC voltage at that current.
  3. Petros.Alexakis
    Mar 10, 2016
    8
    Maybe I stated the question in a wrong way. I have a 6 phase inverter with a phase current of 380A rms of 537A peak if you prefer. I am wondering how to calculate the current on the DC side of the inverter
  4. tcmtech
    Nov 4, 2013
    2,115
    1,752
    And how does this relate to automotive? o_O
  5. Petros.Alexakis
    Mar 10, 2016
    8
    Answering the question will help the calculation?
  6. JoeJester
    Apr 26, 2005
    3,402
    1,226
    Sounds like homework to me.
  7. Kermit2
    Feb 5, 2010
    3,852
    968
    Knowing the percent efficiency of the inverter will tell you the output power if input power is known.
    Ex: 90% efficiency with 1000 watts input power gives 900 watts output power.
  8. JoeJester
    Apr 26, 2005
    3,402
    1,226
    What is the voltage and the current of the output? What is the input voltage?
    Why not post the whole question as you received it?
  9. Petros.Alexakis
    Mar 10, 2016
    8
    Is attitude part of the forum or the answer? No mate it's not homework. The DC voltage is 48 volts and the AC voltage is 38 Volts
  10. tcmtech
    Nov 4, 2013
    2,115
    1,752
    Only when the question comes across as vague and questionable plus possibly not in the most appropriate section of the forum. :oops:
    shortbus likes this.
  11. JoeJester
    Apr 26, 2005
    3,402
    1,226
    So, I understand you have six phases, each at 38v and 380 amperes.
    You want to know the input DC current from a 48 volt source.
    Correct?
