An ideal current source supplys a constant amount of current through any load you connect across it. A real current source can supply a constant current through a specific range of loads (impedances), if you are out of this range the current will not be constan and regulated.What is the difference between Current source and Voltage source?
by Jake Hertz
by Aaron Carman
by Duane Benson
by Aaron Carman
