dc booster ...need help
Discussion in 'The Projects Forum' started by hertz.12, Apr 25, 2015.
  1. hertz.12
    Apr 25, 2015
    36
    hi guys,
    i want make simple dc converter...i want step up voltage 5 to 8 @ 10A>>>>>>>i want the load take the current directly from the battery and the voltage from the booster....i hope you understand what i want......
  2. wayneh
    Sep 9, 2010
    12,379
    3,232
    Understand? You mean guess. You haven't told us anything about the battery or the nature of the load, and explained why you don't use the obvious and simple solution of adding another battery to get more voltage.
  3. hertz.12
    Apr 25, 2015
    36
    sorry for that....
    i want use this simple circuit .. but the load need too high current ..about 10A @ 8v....i am making small heater for my project ....the coil always damage after seconds...i wonder if i could take the output voltage(8V) from the booster but i take the current from the battery ....the battery can handle this current
    and i need variable voltage so i can't adding another battery to get more voltage
  4. #12
    Nov 30, 2010
    16,670
    7,314
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You circuit doesn't really do anything except short the 9V battery about half the time. A 100 Ω load requires 90 mA. So where does this 8V @10 A come from? That's 80 watts. Your input power source will need to supply more than that, like maybe 100 Watts. There is the efficiency thing that must be satisfied.
  6. hertz.12
    Apr 25, 2015
    36
    the load not shown in the pic >>>
    any way to decrease the amp out from boost converter>>transistor may be? how use it?
  7. #12
    Nov 30, 2010
    16,670
    7,314
    Another one? That's about 6 in 2 days.
  8. wayneh
    Sep 9, 2010
    12,379
    3,232
    Let's start with that. What are the details of your coil; how much voltage and/or current does it require? What were you doing when it was damaged? What are the specs of your 9V supply - is it really a small 9V battery?
  9. hertz.12
    Apr 25, 2015
    36
    5 pics 4V battery....the dc boost converter wrok fine and the output 5 - 8 volt....but the coil damage after seconds
    i use small coil 1w>>i know it will and must damage >>>could i use transistor to take the current from the battery direct>>not throw the boost converter?
  10. wayneh
    Sep 9, 2010
    12,379
    3,232
    Wow, I can't understand any of that. You're intentionally blowing up your coil? Why then do you care about the voltage?
    Please - we cannot read minds. We need details. A schematic would go a very long way.
  11. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I think they teach textspeak at most Community Colleges. If that doesn't work hire a teenager for the summer.
  12. hertz.12
    Apr 25, 2015
    36
    ok thanks all...i will buy big coil that can handle high current
  13. wayneh
    Sep 9, 2010
    12,379
    3,232
    How did you get from needing a DC-DC converter to getting a bigger coil?
  14. hertz.12
    Apr 25, 2015
    36
    i have dc boost converter...mosfet+coil+diode+cap.......the coil 150 uh 1W ...i will buy bigger coil 150 uh ..
  15. Alec_t
    Sep 17, 2013
    5,968
    1,135
    If you want a 10A output, your coil (inductor) will need to be able to handle at least 20A without saturating.
  16. wayneh
    Sep 9, 2010
    12,379
    3,232
    Oooooooh, now I get it. I thought he was talking about his heater coil burning up, not the inductor in the boost circuit.
