DC blocking AC amplifying circuit
Discussion in 'General Electronics Chat' started by tenzil, Jun 16, 2016.
  1. tenzil
    Jun 16, 2016
    14
    Hello everyone,
    I need to block the DC or keep the DC at a constant level in the output of the op amp and amplify the AC using the same op amp.
    Currently the DC shift in the input is between 1.6V to 2V
    i don't need any gain for the DC and the gain required for AC is 10 and above.
    When i try to block the DC using the capacitor there is so much of noise in the output.
    I am uploading some of my test circuit and its results.
    please help me to solve this out.
  2. AlbertHall
    Jun 4, 2014
    2,261
    447
    Wild guess - use a coupling capacitor?
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    Welcome to AAC!
    You didn't complete your description...
    To block DC, you can AC couple the signal. If you want a fixed or variable DC offset in the output, you can use a summing amplifier to add an offset.
  4. tenzil
    Jun 16, 2016
    14
    Thank you for your update.
    sorry that my description is not complete.
    Actually the signal is an output of hall effect sensor,the problem is the DC offset is varying with some sensors.So in this case will the summing amplifier work.
  5. dl324
    Mar 30, 2015
    3,376
    651
    Your PDF attachment is 6.6MB. Kindly post smaller files and delete the one in your last post; only one copy is needed.
  6. tenzil
    Jun 16, 2016
    14
  7. tenzil
    Jun 16, 2016
    14
    Sure,
    please find the attachment
  8. dl324
    Mar 30, 2015
    3,376
    651
    Still too large. Post JPG's of appropriate resolution to convey information.
    I question the way R2 is connected. I have never seen the gain setting resistor not having a DC path to ground.
  9. tenzil
    Jun 16, 2016
    14
    please find the attached files,
    The R2 and the capacitor will act High pass filter and block the DC.
  10. BR-549
    Sep 22, 2013
    2,169
    416
    we need the data sheet on the sensor.......and any other components between sensor and amp.
  11. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Can you post your .asc file?
  12. dl324
    Mar 30, 2015
    3,376
    651
    It doesn't work that way. R3 and R2 set the gain. DC blocking is done by putting a coupling cap on the opamp input.
  13. AlbertHall
    Jun 4, 2014
    2,261
    447
    That is, between Vin and R4.
  14. dl324
    Mar 30, 2015
    3,376
    651
    C1 is in parallel with R4, that's not an AC coupling cap.
    EDIT: I get it. You're not telling me where the cap is, you're telling the OP where to put it.
  15. tenzil
    Jun 16, 2016
    14
    please find the data sheet of the sensor
  16. tenzil
    Jun 16, 2016
    14
    Currently in board there is no amplifier b/w sensor and ADC,so because of the DC shift in the o/p of the sensor is different from one another the data what we got from the ADC are not proper.
    so i am thinking of blocking the dc and amplify the AC .
    please let me know if there is any circuit that will meet my requirement
    please find the datasheet of the sensor
  17. tenzil
    Jun 16, 2016
    14
    please find the datasheet of the sensor and the .asc file.
  18. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Try this mod of your asc file.
    Note that your circuit currently has a gain of ~100, so the amp is driven into saturation. Is that your intention?
  19. tenzil
    Jun 16, 2016
    14
    Actually i need a gain should grater than 10,
    That we can adjust
  20. tenzil
    Jun 16, 2016
    14
    Thanks a lot for you update ,
    let me rig this circuit and let you know how it is working.
