dc bias of a common emitter amplifier
Discussion in 'General Electronics Chat' started by confirmguy, Oct 7, 2007.
  1. confirmguy
    Oct 7, 2007
    i did this experiment under that topic.........i built a basic transistor amplilfier known as common emitter amplifier and after connecting every thing i was asked to change the tranisistor with a tranistor of exactly the same type and get the value 4 d base, emitter and collector ................on doing this, there was little or no diffrence and i am asked to comment on it
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Without a schematic, it's hard to see if there might be something remarkable about the change. Do you have spec's on the two transistors?
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I don't understand. Did you read 4Vdc on each lead? If so, the leads were apparently shorted together.
  4. billbehen
    May 10, 2006
    39
    Troubleshooting is not always easy! Maybe one of the Resitors or other parts is shorted or open?
