Dc bias for adc
Discussion in 'The Projects Forum' started by Jonesy, Mar 31, 2011.
  1. Jonesy
    Jul 7, 2010
    20
    How do one bias an AC signal to a DC signal to be measure by an ADC which only accepts positive voltages?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Jonesy
    Jul 7, 2010
    20
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If we have the full requirement, it makes it easier to suggest a solution.
    That converter should work fine, if it gives you the precision you need.
  5. Jonesy
    Jul 7, 2010
    20
    measuring an AC 60Hz sine wave current using a current transformer.
    Need 1mV/1mA sensitivity.
  6. someonesdad
    Jul 7, 2009
    1,585
    141
    You could use an op amp for the offset (i.e., add a DC voltage to the AC waveform).
  7. Jonesy
    Jul 7, 2010
    20
    I try not to use opamp as I do not have positive and negative supplies which the opamps need.
    I tried using the cap followed by a voltage divider, the cut-off is at 15Hz which is well below my 60Hz, blocking the DC component. But tried it on breadboard, it stays at the same voltage no matter what AC signal i couple in. Maybe my voltmeter could not measure this correctly.
