Determine exact DC collector currents of Q1 and Q2.
Q1 is an NPN transistor and Q2 is a PNP transistor.
R4 and R5 were 8Mohms and 6Mohms respectively, so I assumed that the current into the base of Q1 was negligible. Hence doing voltage division, I have a voltage at the base of Q1.
As indicated on the diagram, I have several other voltages found through the standard voltage drops on the transistors. Since ib1 = 0, ic1 = ie1
In determining the collector currents, I am confused on how to proceed. I tried doing KVL but since there are no resistors directly connected to emitters and collectors with the exception of collector Q2 I find it confusing since I can't get a voltage drop.
Thanks.
