Hello there
I am looking for a relay that uses a low voltage DC input (6v or even 3v if possible) that is used to switch on a 120v or 240v AC circuit to drive a small motor. However, the relay has to be normally closed.
Does anyone have any recommendations as I've not seen this configuration readily available.
Thanks in advance for your help.
Winston
Winston
