That is correct.DB is a dimensionless value, just a ratio between two values, where as DBM is a ratio of a value referenced to 1 milliwatt. At least that's how I recall the difference.
Lefty
Roger that.DB is a dimensionless value, just a ratio between two values, where as DBM is a ratio of a value referenced to 1 milliwatt. At least that's how I recall the difference.
Lefty
dB on its own means that the figure which precedes it is so much greater than some other, unstated, figure. It is therefore a (logarithmic) multiplier, but without knowing the unstated figure there is no way of knowing just how large either of them is.... what is difference between db and dbm.
LeftyRetro (Post4) gave the correct and textbook answer.dB on its own means that the figure which precedes it is so much greater than some other, unstated, figure. It is therefore a (logarithmic) multiplier, but without knowing the unstated figure there is no way of knowing just how large either of them is.
e.g. 3dB means a power which is twice as large as another one, or, another way of saying the same thing, a voltage which is 1.41 times as large as another one. In neither case we can't deduce the actual value of the smaller or larger voltage or power.
dBm means that the figure which precedes it is so much greater than 1mW.
e.g. 6dBm means a power which is 4 times greater than 1mW, or 4mW.
Yes, I noticed that too - except that textbooks usually get the conventions right. dB, not DB, and dBm not DBM.LeftyRetro (Post4) gave the correct and textbook answer.
Since we're going to get anal over this I might as well point out that the decibel translates to 1/10th of a Bel but I've never seen a Bel.Yes, I noticed that too - except that textbooks usually get the conventions right. dB, not DB, and dBm not DBM.
And by the way, it's decibel, not Decibel.
