Datasheet
Discussion in 'Electronics Resources' started by Iodem_Asakura, Sep 18, 2005.
  1. Iodem_Asakura
    Thread Starter Senior Member
    Sep 14, 2004
    140
    I saw a component (i think is a trasistor, a really small surface trasistor), and i think it says K3NP6 in the body. I tried to find some information about it, but couldn't find.
    I need to know what it is. May you help me?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Hi iodem_asakura
    I found this link through google.
    transistor datasheet
    It appears that the transistor you have is a PNP small signal device. Probably it is a surface mount version of the 2N3906. The "P" is the year code for 2003 and the "6" is the month code for June.
    The official term for the designation K3NP6 is product type marking code.
    hgmjr
  3. Iodem_Asakura
    Sep 14, 2004
    140
    Thanks a lot. You can't imagine how much have you help me. However the version i saw was a 3-terminal component. But now i only need to figure out which pin is which by the conection.
    Thank you very much. Take care.
  4. Gorgon
    Aug 14, 2005
    113
    This may help you identify the pins: http://www.rockhounding.net/projects/compa...ay_mmbt3906.pdf
    TOK ;)
  5. Iodem_Asakura
    Sep 14, 2004
    140
    Thanks, that is what i needed. By the way, how do you search for datasheets. I think i would never find this kind of datasheets. I searched a lot i didn't find anything. Any searching datasheets tips?
  6. pebe
    Oct 11, 2004
    628
    You can get most datasheets from here.
    http://www.datasheetarchive.com/datasheet/pdf/2916.html
  7. Gorgon
    Aug 14, 2005
    113
    Hi
    I normally use http://www.alldatasheet.co.kr they are quite good. But not this time. This site is good if you know the name, of the component.
    For your transistor I used Google, searching for 'transistor k3n' or something like it. (I can't remember all the words or sequence.)
    You'll find the datasheet with this, but not the same place. I did it from another computer and service provider.
    The clue is to be persistent and to vary the criteria and add as many parameters as possible to narrow the search. I don't know if the order of parameters have any effect, but I may try that too :)
    Searching like this produce a lot of crap pages too, but you need to scan the hits for validity.
    If you know the manufacturer, your first try is on the homepage. To find old and maybe obsolete parts this way is normally useless.
    Philips Semi has a very good list of the -74hc logic family here: http://www.semiconductors.philips.com/
    Good luck!
    TOK ;)
  8. Iodem_Asakura
    Sep 14, 2004
    140
    Thanks for helping. However i think i'll ask you if i don't find something, you're more experienced than i.
    I have been looking today for two datasheets for the following IC's TC4066BP and W990K9828. I found the first, but second seems to doesn't exist. May you help me with this.
  9. Gorgon
    Aug 14, 2005
    113
    Do you know what it is? Type of chip? Number of pins? Function? Digital? Analogue?
    A closer description may help.
    TOK ;)
  10. Iodem_Asakura
    Sep 14, 2004
    140
    I'll tell you tomorrow.
  11. Iodem_Asakura
    Sep 14, 2004
    140
    I have been looking for some transistors datasheet. This time is a C1448 and another transistor that have 330 at the upper side and s-92 below that.
    Can you help me, i could find anything.
