That may most probably be the batch number. It may say that the chip is produced in week 20 2005. But it could also mean something else.i found datasheet for TDA2822 but what about 2005z what is meaning??
Then it comes to electronics never assume be sure. The TDA2822D is the SMD variant. It is compatible with DIP type. Most probably the pinnumbers are also the same. But check to be sure. I once assumed that a SMD opamp had the pin layout as the DIP type. But I was very wrong indeed Of course I found after the PCB was designedthank you very much bertus ,
i understood form you that TDA2822D equal to TDA2822 2005z??? and has a same pin diagram??
how i can check???But check to be sure
By reading the datasheet(s) and compare the two variants. Be aware that if this is a repair job. It will be quite a mess retro fitting a SMD type chip into a board designed for a DIP type chip.how i can check???
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Duane Benson
