data storage
Discussion in 'The Projects Forum' started by jerone, Oct 3, 2008.
  1. jerone
    Aug 30, 2008
    15
    In our business,were engaged in electronic operated water dispensing machine and only powered up on working hours. . What I am looking for is an IC that would log every transaction made by the buttons used for dispensing. Is there any IC that is capable of hold this data without supply on non working hours? Together with the date and time even if the machine is unplugged? Is that possible even if an internal supply is not present? Im just protecting the lost of data in case an internal supply is present then its battery will suddenly malfunction,or tampered by another engineer or technician.
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Does anyone still make the old bubble memory chips? They would work for this.
  3. jerone
    Aug 30, 2008
    15
    Is that possible? Were going to order this from our supplier/manufacturer.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Ramtron makes a line of static ferroelectric ram chips. Mouser carries them with parallel, serial, and SPI interfaces.
