Data sheets?
Discussion in 'Electronics Resources' started by 1213brett, Feb 3, 2015.
  1. 1213brett
    Feb 1, 2015
    13
    I don't understand data sheets. So much info and such inconsistent labeling of parameters. What parameters should I be looking at when selecting mosfets and diodes? I mean What's really important and what different labels will they be using for those same important parameters? Thank you and sorry if this is dumb.
  2. #12
    Nov 30, 2010
    16,660
    7,305
    Survivable voltage and maximum current.
  3. crutschow
    Mar 14, 2008
    13,469
    3,356
  4. Alec_t
    Sep 17, 2013
    5,956
    1,132
    "What's really important" depends on what you are using a FET for. High speed, huge current, high voltage, switchable by a logic-level signal, .....?
  5. shortbus
    Sep 30, 2009
    4,086
    1,665
    For understanding mosfets it doesn't get much better than this for a 'hobbyist'. Probably not 'engineer' level information, but very practical down to earth information.
  6. shortbus
    Sep 30, 2009
    4,086
    1,665
    All well and good, but the "headlines" of a mosfet data sheet don't really tell the truth. :)
  7. #12
    Nov 30, 2010
    16,660
    7,305
    I guess the manufacturers are playing, "First liar doesn't stand a chance". :D
  8. shortbus
    Sep 30, 2009
    4,086
    1,665
    They give these great looking numbers, but don't tell you ,except some times in very fine print, thta the device package is the absolute limit. Like ~ 75W for the common TO-220, and that wattage only with a properly sized heat sink. :(
