Data sheet request
Discussion in 'Electronics Resources' started by a/hakim, Apr 12, 2013.
  1. a/hakim
    Apr 12, 2013
    8
    I am stuck on a Rapitron 42L14 (42'') LED TV for repair... I would appreaciate help for data sheet of inverter IC:
    BD9226EFV
    1511317
    Would like to know at least the Vcc pin # and the value of Vcc itself.
    Other thing: I would like to confirm what type of component is:
    D482
    BA1317
    (most probably a power MOSFET also... found on inverter board of the above-indicated TV)...
  2. mlog
    Member
    Feb 11, 2012
    276
    36
    I'm guessing the D482 is a 2SD482, which is a Silicon NPN Transistor in a TO126 package.
  3. a/hakim
    Apr 12, 2013
    8
    Many thanks ...
  4. KrisBlueNZ
    Member
    Oct 17, 2012
    111
    14
    Your best bet is to Google those numbers. If you don't find anything, I can't suggest anything else to try.
  5. praondevou
    Jul 9, 2011
    2,936
    489
    Post pictures of the components, if possible with legible model #.
    We need:
    - package type
    - name of the component (printed on PCB)
    - a picture of each
