data sheet for crystal oscillator
natann999
Joined Dec 11, 2012
11
hi,
i need help finding a data sheet for the crystal oscillator BSCH14EAG34.368MHZ
description: Crystal Oscillator 34.368MHz 3.3v DIP-8
if there's no data sheet, an explenation on the pins will also be great
i need to know what pin is vcc, gnd and the output
thank you
GopherT
Joined Nov 23, 2012
8,009
In general, oscillatros have Vcc as the highest PIN number, ground is in the opposite corner from Vcc. Output is across from Ground. Pin 1 may do nothing and it may be a chip enable pin that can be pulled to ground to stop the oscillator. If it is a chip enable pin, it may also have to be pulled high to enable it. Try this advice at your own risk on this particular chip.
