data pulse amp
Discussion in 'The Projects Forum' started by Bohemonde, Mar 2, 2015.
  1. Bohemonde
    Mar 2, 2015
    Need to raise data level from 5Vpp to 40Vpp. The pulse is 1microsecond duration and repeats every2 microseconds. The optocouplers and opamps looked at do not exceed 30Vcc. Suggestions?
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    btw, 1μs square pulse every 2μs is a 500kHz square wave.
    Use a transistor.
  3. GopherT
    Nov 23, 2012
    6,312
    4,031
    A single transistor will invert your signal, a second will flip it back.
  4. MrChips
    Oct 2, 2009
    12,636
    3,454
    If you need more than one level converters consider getting ULN2003.
  5. ScottWang
    Aug 23, 2012
    4,930
    777
    The Rb2(100K) maybe too high for 500Khz.
