time to close this thread, theres alot of info above for those whom are reading.
For me, will be reearth grounding the home 20 and shop, finally received the Fall-Of-Potential meter test kit ordered from ebay... The NEC code is 25 ohms while the Ieee stay with 5 ohms or less. Myself, am going for the 5 ohm code. If for some reason your earth grounds won;t go down to what you want, you'll need "earth-enhancment" backfill from the electric supply house. One is called "ultra-fill" its a carbon based conductive back fill to pour in around the length of those ground rods the other is "Bentonite" its a clay based material mined here in the states. While it also does the job, think I would rather use the carbon based material as it performs something like 5-8 times over the clay material... With respect to the data protection the best I was able to come up with is to isolate it "isolation Transformer" due to the GPR, the fault currant/surge will pass through the ground rod system into the wires through your Electronics then back to your telcom/cable providers ground that they are required to install by code.
