Data memory need help ?
Discussion in 'General Electronics Chat' started by vead, Nov 18, 2014.
  1. vead
    Nov 24, 2011
    621
    8
    Hello
    Data memory
    Data memory is used to read and write data
    Example
    Code (Text):
    1.
    2. Address       Data
    3.
    4. 1                     10
    5.
    6. 2                      12
    7.
    8. 3                       14
    9.
    10. 4                      16
    11.
    Load the data from memory address 2 and save into A register ( read data from memory)
    Store data from A register to memory address 3 (write data to memory
    Suppose
    Data memory specification
    Address bus 2 bit
    Data bus 4 bit
    Accumulator register
    How to make data memory? how many address and data register I have to use in data memory ?
  2. Alec_t
    Sep 17, 2013
    5,975
    1,135
    You could do it the hard way, using data latches; or you could (more cheaply), just buy a memory IC.
    Anything from 1 (a 1-bit latch or register) to a gazillion googabytes. That's a bit like asking "How long is a piece of string?". Or were you referring to the 2 bit/4 bit example?
