Hi everyone, this is my first post. Hope I've put it in the right place...
I'm in the process of designing a 'solar cooled greenhouse' system for a university project. We're required to make a working prototype of our concepts and I have hit a bit of a wall. To make my project work, I need some form of electronic control and possibly even data logging to make graphs from for our report.
The way the system works is, air passes through a pad which is saturated with a fluid which dries the humid air. The air passes through a second pad which is saturated with water which evaporates into the air thus cooling the air. The air then passes over the crops being grown and then through a second evaporator pad which is used to cool the first drying pad. (I hope that makes sense to most people!)
The system works by using fans to draw air through the system, and pumps to pump the fluids around the system. What we require is a control system that will monitor the temperatures at different locations through the greenhouse, and adjust fan speeds accordingly. While doing this, it would be great if the data could be logged on a file on a computer via a serial port, or even better USB.
Unfortunately, the group is made up of engineering and design students, none of us know a thing about electronics...
Would any of you be able to point me in the right direction of where I would even start to be able to pull this off. I have some basic electronics knowledge as we have done some simple circuits before, one using a small temperature sensor which turned an LED on and off, but nothing this complicated. I also do a fair bit of programming, but in PHP and other similar stuff...
ed
ed
