I'm doing this as my final year main project.Does this topic is a good one?
yes, n this des algorithm will be burned on XC3S400so, your plan is to encrypt stuff by sending it through an uart transceiver?
A serial interface for transferring data to and from a rotating hard drive, SSD, or Compact Flash chip. I can see numerous interesting applications for such a device especially if you can find a way to make decryption difficult without the proper keys.what is this SATA?
In your project, what does the DES have to do with the UART?yes, n this des algorithm will be burned on XC3S400
The forget DES. While I do not believe that the NSA put a backdoor into DES (all indications are that the mysterious tweaks the NSA made to the S-boxes actually strengthened it against differential cryptanalysis which, at the time, was unknown to anyone except the NSA), its key strength, at 56-bits, is just too low to be secure with today's machines.A serial interface for transferring data to and from a rotating hard drive, SSD, or Compact Flash chip. I can see numerous interesting applications for such a device especially if you can find a way to make decryption difficult without the proper keys.
In particular you need to devise a method to guarantee there is no backdoor for the NSA or "other" government agency like B-613 to penetrate the device.
by Aaron Carman
by Aaron Carman
by Jake Hertz
