data acquisition system(DAQ)
Discussion in 'Embedded Systems and Microcontrollers' started by yash5730, Sep 5, 2016.
  1. yash5730
    Aug 31, 2016
    hey guys,
    I m college student and working on a some big projects which includes lot of sensors. for taking that system to its maximum efficiency I need all the values stored in some memory. so I need to make data acquisition system using some controller.
    can somebody guide me about what approach should I have to achieve my target.
  2. KeepItSimpleStupid
    Mar 4, 2014
    1,265
    222
    You have to define the inputs and outputs. The general accepted practice is to use a PLC or Programmable Logic Controller.
    There are interfaces like LabView (It's a "data-flow" programming language) and Wunderware that can provide an HMI for the PLC. LabView is the deFacto standard for Data Aquisition in Lab environments. Colleges may have a site license.
    Modbus is a simple protocol standard that would allow cross-platform communication if allowed.
    Check out the "Smart relay" which is a very tiny PLC. www.automationdeirect.com and http://ab.rockwellautomation.com/Programmable-Controllers
    There's barely enough info to even start to suggest anything.
  3. wayneh
    Sep 9, 2010
    12,379
    3,232
    Or you could use something like a LabJack controlled by your PC.
  4. dannyf
    Sep 13, 2015
    2,196
    417
    if someone doesn't make this somehow somewhat clearer, someone will provide some help to someone somewhere else so some of us can get you somewhere on the right path to somewhere.
  5. shteii01
    Feb 19, 2010
    3,500
    511
  6. KeepItSimpleStupid
    Mar 4, 2014
    1,265
    222
    e.g.
    5000 switches
    or
    Temperature/humidity in a 20 story office building
    or
    Flow, pressure,
    Is this thing a DAQ system or a process control system? Is it more of a try recipes or research? Are they all clumped together or miles apart? Have you selected the sensors? How do you eliminate ground loops?
    GPIB? USB?
