Dark Sensor LDR Circuit
Discussion in 'The Projects Forum' started by Rip, Apr 28, 2016.
Thread Status:
Not open for further replies.
  1. Rip
    Apr 28, 2016
    12
    How would I go about designing a dark sensor circuit using an LDR and transistors? The LDR value for light is around 7k ohms and when its dark it is around 1M ohm. The transistors are 2N3904. The circuit has a 5V buzzer and a 2V (10mA) LED. The circuit should work as follows: when there is sufficient light falling on the LDR, the transistor should be in saturation and the LED should be lit and when there is not sufficient light falling on the LDR then that transistor is in cutoff and the LED is not lit and the buzzer should sound. How would I go about designing this circuit? Any help is greatly appreciated
  2. dannyf
    Sep 13, 2015
    2,196
    417
    Typically it is a divider. Your transistor will have a threshold voltage to turn on / off. You just to pick a resistor so that
    LDRlight/(R+LDRlight) << Vthres, and LDRdark/(R+LDRdark) >> Vthres.
    In addition to that, you need to make sure that the base current isn't too light.
    A few trial and error will do.
  3. Rip
    Apr 28, 2016
    12
    Where would I put the buzzer and the LED for this circuit? I'm just not sure how to lay it out to make it work
    Any help please?
  4. tracecom
    Apr 16, 2010
    3,879
    1,396
    If this is a homework assignment, it should be in the homework section.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
Thread Status:
