DAQ for EMG signals
sailorjoe
Joined Jun 4, 2013
365
From my read of the datasheet, the device may not be directly compatible with your EMG signal, which you describe as 0-8ma. The LabJack has voltage inputs, and it has expansion boards for 4-20ma current signals. So I think you'll need to convert you current signal to a voltage first, then send it to the LabJack.
I'd keep looking for something specifically designed for EMG work.
https://www.motion-labs.com/prod_data_acq.html
