Dangerous to rip parts from old PSU's?
Discussion in 'General Electronics Chat' started by Jacob J, Dec 30, 2010.
  1. Jacob J
    Thread Starter Active Member
    Jun 18, 2009
    159
    Hello
    Is it dangerous to rip an old power unit from a computer? I mean, is there any electricity left in the unit, like charged capasitors or something like that? The PSU's have been without any power for 6 month now.
    /Jacob
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    After a few weeks, only if it is still plugged in. John
  3. Jacob J
    Jun 18, 2009
    159
    Okay, so I shoud be safe. What components to look out for if I want to be extra carefull?
  4. #12
    Nov 30, 2010
    16,704
    7,354
    Capacitors. They are the only thing in there that can store electricity.
  5. Jacob J
    Jun 18, 2009
    159
    Okay, but a few weeks should be enough for them to have drained off their power?
  6. #12
    Nov 30, 2010
    16,704
    7,354
    see post #2
  7. marshallf3
    Jul 26, 2010
    2,358
    201
    If in doubt take a clip lead and short the capacitors out. Put a 470 ohm resistor on one clip end if you don't like loud noises in case they happen to be holding a decent charge.
    In all actuality, due to the cheap caps they use in them and by design they'll all discharge in a few days max.
  8. TheLaw
    Member
    Sep 2, 2010
    228
    An old trick I learned was to unplug the computer. Then push the power button while it is unplugged. An LED may (or may not) flash on and then off quickly. This should drain the big primary cap. Some of the el cheapo caps in regular OEM power supplies have barely any capacitance at all. I've seen a 450W Acer power supply with an 168uF capacitor on the primary side. Frightening.
    That's the less technical way..There are of course more effective ways as noted above.
