Damping ratio and poles for transfer function
Discussion in 'Homework Help' started by janine, Jul 17, 2009.
  1. janine
    Jul 17, 2009
    5
    Transfer function: 5 / s2 +2s +1
    These are the steps I’ve done:
    Kωn2 / s(s2 + 2ςωns + ωn2 )
    Y(s) = 1 / s + A1 / s-P1 + A2 / s-P2
    y(s) = 1 + A1expP1t + A2expP2t
    P1 + P2 = poles are equal to the roots
    S2 +2ςωns + ωn2 = 0
    P1, P2 = -2ςωn +- √ 4ς2ωn2 - 4ωn2 / 2 = ςωn +- ωn √ ς2 – 1
    A1 = -(kς / 2√ ς2 –1) – k / 2
    A2 = (kς / 2√ ς2 –1) – k / 2
    But I don’t know how to find the poles and damping ratio please help!
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    S^2 + 2s + 1 has two equal roots at s=-1.
    There are two poles, each at -1 +j0 on the complex plane.
    ω0^2=1
    So ω0=1
    2*ζ*ω0=2
    2*ζ=2
    Damping factor ζ=1 (critically damped)
  3. janine
    Jul 17, 2009
    5
    thank you! But does it not matter that this formular hasn't been used?
  4. janine
    Jul 17, 2009
    5
    Also just another quick question... this transfer function is confusing me: 16/4s^2 + 4s +8
    as it has complex roots I don't know how to begin solving it?
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    Not necessarily - You just need to know how to equate the actual coefficients in the particular example with the general coefficients in the standard form of the equation you include above.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    16/(4s^2+4s+8) = 4/(s^2+s+2)
    the roots of s^2+s+2=0 are -1/2 ± j(√7)/2
    Use the normal method for solving a quadratic equation - where negative roots have the imaginary operator.
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    I guess I meant square roots of negative numbers take the complex operator.
  8. janine
    Jul 17, 2009
    5
    Thanks that's really helpful! I've worked them all out now, but then the next stage was to find the peak time, rise time, settling time and overshoot. I managed to do this for all of them except this one: 1 / s^2 +8s +4, the poles are -0.54 and -7.5, zeta= 2 and ωn=2, I know it has no overshoot as it's overdamped, I worked out the settling time is 1second, but I have these formulas for rise time: pi-arctan((√1-ζ^2)/ζ) and for peak time: pi/ωn√1-ζ^2, but zeta is too big therefore you get j again but I didn't think this could be used in peak and rise time?
  9. t_n_k
    Mar 6, 2009
    5,448
    783
    Rather than just plugging numbers into a formula, you could write down the time domain solution for the example in question.
    Then either plot the time domain solution or directly solve for the conditions that define a particular parameter.
    Consider rise time.
    This is normally considered as the interval over which the function goes from 10% to 90% of its final value. Given the time domain function, you should be able to solve for the times at which you have 10% & 90% conditions - T10 & T90. Hence Trise=T90-T10.
