damaged files in electronics forum
Discussion in 'Feedback and Suggestions' started by Yeti, Sep 17, 2005.
  1. Yeti
    Thread Starter Active Member
    Jul 26, 2005
    35
    Someone made a post in the general electronics forum that has been sticky'd or pinned, that contains two pdf files.
    When i try to open them, Adobe acrobat says the files are damaged and it cant open them. Is this an error on someone else's part or is it my computer?
  2. mozikluv
    Jan 22, 2004
    1,437
    hi,
    pls. show the reference # of that post so the moderator or the administrator or other members can check that problem. ;)
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Hi Yeti,
    I have tried opening the two pdf files using Adobe Acrobat 7.0 with no problem. You didn't mention what pdf veiwer you were using, but the mentioned error message is known problem with Adobe Acrobat 6.0 when trying to open pdf files from the web. If you are using Acrobat 6.0, you can save a copy of the file using right-click>Save Target As, this will allow you to open the pdfs from a local drive with no problem, or even better upgrade to Acrobat 7.0.
    (Just a note: If you choose to upgrade to Acrobat 7.0, you are advised to install the upgrades 7.0.1, 7.0.2 and 7.0.3)
    Hope that helps a little.
  4. Yeti
    Jul 26, 2005
    35
    Yeah i do believe that it is on my end :(
    I only have adobe acrobat reader 5.0 so ill have to upgrade sooner or later
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I haven't heard of the problem affecting Acrobat 5.0, but it wouldn't surprise me if the bug was also present in that version.
