DAC
snp2411
Joined Mar 11, 2009
11
hi...
can anybody help me in getting perfect analog output from the DAC(0-10v).....and thia output is given to the firing circuit for triac....if possible post me the circuit...and the input of the DAC will be from microcotroller...
thanks in advance...
beenthere
Joined Apr 20, 2004
15,819
Do you have a circuit design in mind for the triac triggering? If so, it might be easier to trigger with an output pin changing state.
mik3
Joined Feb 4, 2008
4,843
What do you mean by a perfect output?
If you mean a smooth varying output (not in a step form) then this is not possible because you need infinite resolution to achieve it.
