DAC to 110V
Discussion in 'The Projects Forum' started by ingeeg, Sep 17, 2012.
  1. ingeeg
    Sep 13, 2012
    I have a DAC with the output of 1-5 V, how can I convert it to have 1-110v. what methods can be used.
    Thank You
  2. wayneh
    Sep 9, 2010
    12,391
    3,246
    Is that 1-110V DC? How much current and/or power?
  3. ingeeg
    Sep 13, 2012
    actually it's a DC. Simply I want to control the amplitude of the outlet on the wall digitally with micro controller.Further I will use it as to dim the light. Looking for the solutions
    thank you
  4. ScottWang
    Aug 23, 2012
    4,933
    777
    This is the idea to be your refernce.
    DAC (1~5Vdc) → E amp using Op Amp(Vo≦36Vdc↓,Vcc≦40V) → Transistor(Push-Pull Output) 110Vdc.
    The Vcc and GND of the transistor, must be higher than 110Vdc + (1.1V*2).
  5. vk6zgo
    Jul 21, 2012
    677
    85
    Do you mean to control the voltage appearing at a wall power socket of the same kind as normally used for the AC mains?
    I would suggest you use a completely different type of outlet,as someone other than yourself may connect some appliance which either draws more current than your proposed device can supply,or which uses a transformer.
    In each case,it will mean destruction for your device,& maybe the appliance as well.
    In some administrations,it may be illegal to connect 110V DC to a standard wall socket.
  6. t06afre
    May 11, 2009
    5,939
    1,222
    Purchase a light dimmer. They work fine with light bulbs, at least. From your original suggestion on how to solve this. I can see that you lack some experience in order to do this. And it is also not legal to connect such home-brew equipment to the mains. The reason, it is highly unsafe.
