Dac programming in Quartus II
Discussion in 'The Projects Forum' started by shom_show, Aug 13, 2013.
  1. shom_show
    Sep 4, 2010
    15
    Hi friends,
    I am trying to write programs for generating DAC, offsetdac and adcdaccount in Quartus II. But I am ending it with errors. If anyone has the program or some related materials for the previous mentioned blocks, please post it in this Thread or send it to the email - <SNIP>.
    Thanks in advance.
    Sumanta Kumar Show
  2. tshuck
    Oct 18, 2012
    3,531
    675
    You have not defined what those things are, nor how they are used. Please try harder...
  3. shom_show
    Sep 4, 2010
    15
    The blocksets which I need are (DAC, offsetdac and adcdaccount). Pin configurations of individual blocks are as below -
    offsetdac-
    1) Input ports - dataa[11..0], datab[11..0], datac[11..0], datad[11..0]
    2) Output ports - DACdataa[11..0], DACdatab[11..0], DACdatac[11..0], DACdatad[11..0].
    adcdaccount-
    1) Input ports- clock
    2) Output ports- adccount[10..0], daccount[10..0].
    DAC
    1) Input ports- clock, daccount[10..0], dataa[11..0], datab[11..0], datac[11..0], datad[11..0].
    2) Output ports- DACSELA, DACSELB, /DACLDAC, /DACWRITE, /DACCS, DACDATA[11..0], /DACRESET.
    Please help me out as it is urgent at (sumanta.show@gmail.com).
    Thanks in advance.
    Sumanta Kumar Show
    Research Scholar
    E&E Dept.
    NITK Surathkal
    Karnataka, India
  4. tshuck
    Oct 18, 2012
    3,531
    675
    A full year has passed, yet you still don't give any useful information.
    Good luck!
  5. shom_show
    Sep 4, 2010
    15
    Dear tshuck,
    Can you just specify what information exactly you needed to suggest on my problem, so that I can provide you with all the necessary inputs.
    Waiting for your response.
    Sumanta
  6. tshuck
    Oct 18, 2012
    3,531
    675
    The necessary input is what you know about the problem.
    What is the overall purpose? What kind of device? What will be attached to the FPGA? What are the modules supposed to do? What do they connect to? What ate the interfaces?
    Try to give others enough information to actually help you by pretending you have to present this information to a superior - give overall information and details as needed.
