General question :
A DAC can give out a glitch at major code change.
one option to 'minimize' this on the output is to use a R/C low pass filter.
Debate raging here, does the filter 'remove' the glitch , or smear it over time ?
One side here says the glitch is attenuated,
effectively the glitch is dissipated as 'heat' in the capacitor.
One side says the glitch is attenuated ,
the impedance of the DAC output forms a frequency dependent voltage divider,
but the energy before and after the filter is the same, its just spread out in time,
Anyone got any thoughts that I can hook together ,
