D13007 - NPN Silicon Power Transistor Replacement
Discussion in 'Electronics Resources' started by silvestrogatto, Nov 12, 2011.
  1. silvestrogatto
    Nov 12, 2011
    I am replacing a D13007 NPN Silicon Power Transistor and can not find a replacement.
    Any help?
    Thanks,
    s.
  2. praondevou
    Jul 9, 2011
    2,936
    489
  3. jimkeith
    Oct 26, 2011
    539
    99
    D13007 is an NPN silicon bipolar transistor in a TO-220 case
    Ic Max: 8A
    Vcbo: 700V
    Vceo: 400V (a figure of merit as transistors are not applied like this)
    hFE: 5 to 30 @5A
    http://pdf1.alldatasheet.com/datasheet-pdf/view/78029/AUK/D13007.html
    BU508AF is the only device that seems to come close:
    Ic Max: 8A
    Vces: 1500V (Wow! this is with B shorted to E--essentially Vcbo)
    Vceo: 700V
    hFE: 5 min @ 4.5A
    http://search.digikey.com/us/en/products/BU508AF/497-8748-5-ND/2043589
    http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00153827.pdf
    The intended application may be different, but will work for other apps too.
