D Flip-Flop
Discussion in 'Homework Help' started by battery, Jan 28, 2009.
  1. battery
    Jan 28, 2009
    Just wanted check if i understand correctly -
    Here is the DFlip FLop
    In the start all triggers have info of hex A (base 16) (meaning 1 0 1 0).
    the question - 1) what info will be in these triggers after 1. , 2. , 3. , and 4. impulse.
    As i understand this scheme makes a loop -
    after first impulse there will be - 0 1 0 1
    after second - 1 0 1 0
    third - 0 1 0 1
    and fourth - 1 0 1 0
    Am i right? Or have i understood this completely wrong. :)
  2. mik3
    Feb 4, 2008
    4,846
    63
    Is the input of the second flip flop connected to the Q' of the first flip flop? Or it is just a mistake and it should be connected to Q?
  3. battery
    Jan 28, 2009
    Eh, there is no mistake, for some reason i didn`t notice that. :)
    So, it`s not as easy as i thought. So all the 0`s and 1`s are inverted when they go into the first flipflop ?
  4. mik3
    Feb 4, 2008
    4,846
    63
    Yes, at each impulse Q3=Q0, Q2=Q0', Q1=Q2 and Q0=Q1.
  5. battery
    Jan 28, 2009
    i hope that this is correct now -
    impulses
    1) 1101
    2) 0011
    3) 1110
    4) 0101
  6. mik3
    Feb 4, 2008
    4,846
    63
    I find
    1010
    0101
    1010
    0101
  7. battery
    Jan 28, 2009
    Interesting, it looks like something i wrote in my first try.
    So by giving the first impulse the numbers don`t switch ?
  8. mik3
    Feb 4, 2008
    4,846
    63
    They change!!
  9. Cabwood
    Member
    Feb 8, 2009
    20
    After each pulse:
    Q3 becomes whatever Q0 was before the pulse,
    Q2 becomes the inverse of whatever Q3 was before the pulse,
    Q1 becomes whatever Q2 was before the pulse and
    Q0 becomes whatever Q1 was before the pulse.
    This gives me:
    at start: 1010
    after pulse 1) 0001
    after pulse 2) 1100
    after pulse 3) 0010
    after pulse 4) 0101
