D Flip Flop Up/Down Counter
Discussion in 'Homework Help' started by viyh, Nov 14, 2010.
  1. viyh
    Nov 14, 2010
    I'm pretty much a n00b. Can you guys take a look at this and give me any feedback? I believe it works, I'm just not sure if there is an easier way. It's a up/down counter using D Flip Flops (those were required for the assignment).
    The assignment: "Design a 3-bit up/down counter using D flip-flops. It should include a control input called !Up/Down. If !Up/Down = 0, then the circuit should behave as an up-counter. If !Up/Down = 1, then the circuit should behave as a down-counter."
    Thanks!
    -Joe
  2. viyh
    Nov 14, 2010
    Oops, that version had a bug. This is the "new final" version, which I've tested more thoroughly. Comments/feedback are welcome, although I've already turned it in. :)
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
  4. viyh
    Nov 14, 2010
    Wow, sweet, I haven't seen that before. Thanks a lot!
