D flip flop from T flip flops
Discussion in 'Homework Help' started by amorphos, Apr 2, 2015.
  1. amorphos
    Apr 2, 2015
    Question: Show how a D flip-flop can be constructed using a T flip-flop and other logic gates.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Are you sure it is possible?
    The converse of making a T from a D is easy.
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    Any circuit that you can make with any of the basic edge-triggered FF types (JK, D, T) you can make with either of the other two. This includes implementing the other two FF types.
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    You need to show YOUR best effort to solve YOUR homework problem.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I guess I'll be interested in the result.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    Think about it for a moment and it will probably come to you with a head slap.
    With a DFF if you tell me what the value of D is (during the critical setup/hold window) I can tell you what the value of Q will be after the next active clock edge.
    If I give you a TFF and you know what its current Q output is and I tell you what I want the next Q output to be, can you tell me if you want it to toggle or not?
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I suppose, if gating the clock is fair game. I didn't make that assumption initially, since I would seldom if ever do that in practice.
  8. WBahn
    Mar 31, 2012
    18,087
    4,917
    Why do you think you would have to gate the clock?
    Perhaps the confusion is on just what a TFF is:
    http://en.wikipedia.org/wiki/Flip-flop_(electronics)#T_flip-flop
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Ah..you're right. In my text (ca. 1960), the toggle flip-flop had only a single input, the clock input. That explains why I was having a hard time visualizing how to do it. That and nobody ever made an integrated circuit that implemented one, could explain a my confusion. Old dogs should really try to learn new tricks.
  10. MrChips
    Oct 2, 2009
    12,635
    3,453
    (Edit: I started typing a response 5 hours ago but got distracted.)
    Yes, it is possible.
    A T-flip flop has a T input.
    Draw a truth table of all possible states of the present Q and the given D input. Show the desired T input required to implement the D-type flip-flop result.
    You should be able to arrive at a logic function to give the solution.
  11. Papabravo
    Feb 24, 2006
    10,340
    1,850
    As I explained I was laboring under an antiquated definition from a very old text. With the proper definition of the device it is straightforward.
  12. MrChips
    Oct 2, 2009
    12,635
    3,453
    Understood. That is why 5 hours ago I wanted to point out that a T-type filp-flop has a T-input.
  13. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It's all good, and now I know something I didn't know when I woke up this morning.
