D cell.
Discussion in 'General Electronics Chat' started by bug13, Jul 16, 2013.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    Has anyone tested the short circuit current of a D cell, I would like to know if you have any info, thanks guys
  2. TheComet
    Member
    Mar 11, 2013
    88
    12
    Rule of thumb is 20mA.
    Refer to the data sheet of the specific IC for more information.
  3. bug13
    Feb 13, 2012
    1,213
    38
    The data sheet only give up to 500mA discharge current, it doesn't give short circuit current tho.
    Edit: I am referring to D type dry battery like this one here
  4. Ramussons
    May 3, 2013
    562
    92
    I've seen a fully charged NiCd D cell giving 8A on a short; a New Alkaline 4A.
    Ramesh
    bug13 likes this.
  5. bountyhunter
    Sep 7, 2009
    2,498
    507
    Alkaline D cells sometimes have internal resistance above an Ohm, so maybe one Amp or less.
    bug13 likes this.
  6. Shagas
    May 13, 2013
    802
    74
    Good guys energizer generously provide datasheets for their batteries :
    Alkaline D cell -> http://data.energizer.com/PDFs/E95.pdf
    150-300mohm IR , you can extrapolate from there
    Nicd D cell ->> http://data.energizer.com/PDFs/CH50.pdf
    20-30mohm IR !!
    Nimh D cell - >>> http://data.energizer.com/PDFs/NH50-2500.pdf
    11mohm IR charged !!! (i'm starting to sweat now)
    Judging by the datasheets the max current very heavily depends on the Battery chemistry. Alkaline being the wimpiest , followed by Nicd and Nimh taking the gold and 2 hot babes home
    bug13 likes this.
  7. bug13
    Feb 13, 2012
    1,213
    38
    I am dealing with Alkaline here, it looks like I need to add a current limiting circuit just in case there is a short circuit.
    Thanks for your info Shagas!
  8. JoeJester
    Apr 26, 2005
    3,401
    1,218
    sounds like a job for a fuse.
  9. Shagas
    May 13, 2013
    802
    74
    What are you making?
  10. Shagas
    May 13, 2013
    802
    74
    Doesnt neccessarily have to be . Might be current limiting for a motor or something
  11. bug13
    Feb 13, 2012
    1,213
    38
    Since you suggested, the total resistance in the path (I am switching a RC servo off when not use) is:
    • 150mOhm x 4 (I am using 4 D cell)
    • 600mOhm (fuse resistance)
    • 60mOhm (mosfet Ron)
    This will give about 4.7A when short circuit in fresh batteries.
    I am thinking using this fuse (the B one in the table and graph) and this mosfet, how's my choice??
    I am guessing the RC starting current is about 1A, normal operation is under 100mA
  12. djsfantasi
    Apr 11, 2010
    2,905
    878
    What make and type of RC servo are you trying to switch off? You realize that unless power is maintained and a signal repeated to a hobby RC servo, it cannot maintain its position and will move under pressure?
  13. bug13
    Feb 13, 2012
    1,213
    38
    Just a RC/mini 6VDC servo, when it is not used, there won't be any pressure. The goal is to maximum standby power.
    I have already built one up, now I need to maximum standby power and add protection if necessary.
  14. BobTPH
    Jun 5, 2013
    806
    121
    Don't base the fuse on the that battery might supply, base it on what the cicrcuit should draw. Set it to maybe twice that.
    Bob
