D.C. Motor
Discussion in 'General Electronics Chat' started by richbrune, Nov 22, 2006.
  1. richbrune
    Thread Starter Senior Member
    Oct 28, 2005
    106
    I attached a d.c. motor to my scope as shown in the attached files.
    I'd like to know the following:
    Did I accurately demonstrate that the current and voltage are in phase? If so, can I ignore reactance, and take the r.m.s. voltage that is shown across the 1 ohm resistor, and call it the current for a power calculation?
    Thanks again, Rich
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It's a DC motor. You only have phase realtionships in the case of AC motors, where the inductance of the motor coils causes the current waveform to lag the applied voltage waveform. To see something like that in a DC motor, you would have to rectify a low voltage transformer output, but not filter it before applying it to the motor, producing pulsating DC. If the motor was big enough, you might be able to see the current lagging the voltage on your o'scope.
  3. richbrune
    Oct 28, 2005
    106
    The fluctuations in the voltage drop across the motor and the 1 ohm resistor are not the result of inductance?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    They might be the result of going from one commutator segment to the next. Motor EMF will vary as the armature field reacts against the coil's field, and as the commutator switches. Quality of the brush contact can also cause variance in motor current.
