D/A converter
Discussion in 'Homework Help' started by Hello, Mar 7, 2009.
  1. Hello
    Thread Starter Active Member
    Dec 18, 2008
    82
    A 10-bit D/A converter has a step size of 10mV. Determine the full-scale output voltage.
    My answer came to 10.23 volts but not sure if it is the correct answer.
    Any help is greatly appreciated.
  2. silvrstring
    Mar 27, 2008
    159
    If you mean V(out max), then yes. You are correct.
    V(fs) = step_size x 2^n
    V(out max) = V(fs) - step_size
  3. Hello
    Dec 18, 2008
    82
    Thank you.
