CZS-13B RF module 433mhz
Discussion in 'Wireless & RF Design' started by mousepad, Dec 6, 2011.
  1. mousepad
    Nov 3, 2008
    8
    Can somebody help me to find this module's datasheet or Schematic?
    there Are 3 pins
    RXD
    RXD-
    TE
    can somebody explain me what are those? Please.
    Thank You
  2. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
  3. praondevou
    Jul 9, 2011
    2,936
    489
    http://www.szsaw.com/En/html/product.asp?id=344
    You could try to measure if -RXD and GND are connected (Ohmmeter). If so GND (-RXD) can be connected and will be the reference for the output signal. If not I suggest you contact the manufacturer and ask them how to hook it up. The TE pin is obviously not used for normal operation.
    Btw, it's for OOK modulation.
  4. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    What thats modulation..?
  5. praondevou
    Jul 9, 2011
    2,936
    489
    It means ON-OFF-KEYING. The carrier is just turned on and off bitwise. That's the modulation.
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Occhhhhhhhh...
    Its so simple.
