Cypress CY3210-PSoCEVAL1
Discussion in 'Embedded Systems and Microcontrollers' started by jey11, Jun 7, 2010.
  1. jey11
    Jun 7, 2010
    I have Cypress CY3210-PSoCEVAL1 kit and CY8C29466-24PXI IC. I am new to microcontroller programming. I would like to build a circuit and programming for the following requirements.
    Only one Input 2-14 V. For example 2,4,6,8,10,12 V
    The Output should be LEDs. assigend led for depends on the input.
    How can I do this? Any suggestions and help much appreciated.
    Please suggest any good site for MCU programming tutorials.
    Thanks for the help.
  2. R!f@@
    Apr 2, 2009
    8,792
    771
  3. Markd77
    Sep 7, 2009
    2,803
    594
    Sounds like a good project to start on. If the voltage you are measuring has reasonable current capability then a simple resistor voltage divider can be used to reduce it to a voltage range that the micro's ADC can handle. If not then an op amp buffer and voltage divider can be used.
  4. jey11
    Jun 7, 2010
    The input current about 4-8 mA. Is that possible to get sample code I can start work with.
    Your help much appriciated.
